ZenFone 7 Pro Thermal Throttling Issue
after other tests, i realized that the asus zenfone 7 pro is presenting serious problems with performance drops in the game genshin impact ... i decided to use a "CPU Throttling Test" app in it I could see how stable the Motorola Edge Plus has remained Asus Zenfone 7 Pro suffered terrible oscillations, which may explain the drop frames of the game mentioned above. The kernel of this device is in need of some optimization on top of that.
I thought that this could be a problem exclusive to my zenfone 7 Pro, but I tested it with other people who have the same device and in fact are having the same problem.
Comments
Where is the devs to give a answer ?
Have some patience...
Did you use high performance mode instead of balanced?
Yes, I already try. But no results.
Well you can see in your screenshots above that the Motorola Edge Plus wasn't running at the same clock speed. So you're not comparing apples with apples. I also don't know if both devices were tested with the same ambient temp
Same condition. Is same soc, but Zenfone 7 Pro have Little overclock...
just test it with some Zenfone 7 Pro from you and also try running the genshin impact game and you will see what I am talking about is true and I want improvements to be made. I have already talked to Marcel Campos about the problem and I am also reporting to you that some optimization is done on top of that.
Motorola have : Snapdragon 865
Zenfone 7 Pro: Snapdragon 865+
Well, being a newer soc he should behave better but it doesn't
I made another test with "super power saving mode" I don't get any thermal throttling issue, performance mode have some bad optimization on profile. The only thing I think stranger is stand by mode on this new update, I get some issue with battery drain. For example, on Motorola Edge Plus I get 1% drain with 8h without touching it, on Zenfone 7 Pro with same time, I get 4~5% drain issue. @Anders_ASUS Please notify this info for team analisys this issue. Thanks.
