My phone battery is draining due to Android system.
Hi current
Make sure you are on latest software version which is .122 if not, you can check by
Go to setting => System => About => Software information.
If you have already updated please share the overall SOT of your phone:
SOT(Screen on Time) can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
WTF!! Only 12 days old mobile and this much battery drainage.
Please help!
Comments
Hi current
Please help!
