Audio output Feedback for max pro m2-(434)
Dear Asus, (please fix it down... in next update)
1- Max pro m2 audio output is very worst in 434 beta version..There is no base in it both speaker and earphone.
While the both frimware (97/101 pie) is many times better.... Not as good/loud as oreo But the best to hear.
Other than that everything is fine so far..
Comments
No bass in headphone and poor volume in 434 update
A guy on the previous beta got Bass issue fixed after adb uninstalling of icepower (adb shell pm uninstall -k --user 0 dk.icepower.icesound ).
Try it out
Can you try it uninstall icepower
I have tried this and the sound is clear and loud with base. Try it.
Inaccessible or not found
It show inaccessible or not found
I have already done But not as good as it was in 97/101
only little effect use on earphone.
but guy this process is not authentic go own risk.Similarly, Asus phones have fewer problems
First install adb drivers for max pro m2 from this link
https://www.xda- developers.com/quickly-install-adb
And follow the procedure.
Then copy and paste this command
Hi there, thank you for highlighting the issue. We have made a note of the feedback and will share it with the relevant team.
Sound improvement on Android 10, WW-17.2018.2012.434 firmware
Option for Windows 10:
1. Install Minimal ADB and Fastboot. (I installed adb-setup-v1.5.2).
2. Go to: Settings - About phone - Find the build number and tap on it several times until you see: "now you are a developer."
3. We go: System -For developers - USB debugging - Turn on.
4. We connect the phone to the computer (without turning off the phone), a message will appear like: enable USB debugging - allow. Android Composite ADB Interface will appear in Device Manager.
5. Run PowerShell as administrator and enter the commands:
adb devices
adb shell pm list packages
adb shell pm disable-user --user 0 dk.icepower.icesound or, if you want to completely remove: adb shell pm uninstall -k --user 0 dk.icepower.icesound
6. After restarting the device and check the sound.
I managed to fix the sound.
