Need help regarding gesture navigation Max Pro Android 10beta
can anyone tell me how to remove this gap while using full screen gestures with keyboard
it is so annoying
is there any way to remove this useless gap?
it is so annoying
Comments
This is default A10 behaviour on every device while you activate keyboard to type, So this Gap cannot be changed or tweaked
Thanks!
Turn on developer option
Open setting ,search (smallest width)
Now set smallest width to 410
But chin size will not reduce while using keyboard because of dropdown button
