Asus Zenfone Max Pro M1 Android 10 438 build
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Installed 438 build successfully on my Asus Zenfone Max Pro M1
1
Comments
Any bugs?? And how's the performance??
Found two bugs I think they were in the previous build as well (This is my first Android 10 beta experience)
1. Unable to remove settings suggestions option in Settings option (Check Screenshot)
2. Unable to remove or move the google search bar on home screen
Performance is good so far. Smooth experience.
Battery backup or charging speed??
Battery backup seems good. Haven't charged yet
I want to install this beta.. can you answer some questions?
1 - from which pie version you upgrade?
2- data wiped ?
3- ask any password after installation ?
4- you have any lock before install ation like fingerprint , password ?
He installed this version few minutes or hours back. How is it possible to judge battery backup?.
Have to wait for few days to know the exact backup with the new firmware after update.
Bro he upgraded from latest Pie build & removed pasword/pin/fingerprint every security setting before flashing upgrade. Then it won't ask for factory reset during upgrade, I Believe as he said in recent post on A10 discussion.
Vro search for "Settings suggestions" app from seach bar in settings & clear app data of that app, if still suggestions not removed, disable that app. See if that works.
Remove every security settings like pin fingerprint etc before upgrade.
Remove every fingerprint and password then install it. I upgraded from stable pie
I did cleared data and the previous suggestions vanished but this add email doesn't. And there is no option to disable it
Both are Google's Official AOSP behavior for Android 10
Kiya Bkwas He Jab Bhi Koi Bug Hota He Usee Tum, Normal Behaviour Of ASOP Bol Dete Ho, Yha Koi Mjak Chal Rha Hee Kiya
Lol..asus kuch bhi modification nahi karta.. jesa sources he ekdam same roll-out kardeta he.. unlogoko koi kaam hi nai karna..
Kuch krenge to or bugs create ho jayenge..or fir unse kuch thik to hona h ni😂😂 islie vo as it is provide kr dete h har chiz😂😂😂
I am really happy to see the latest December security patch and December Google Play security update to my max pro M1 .😊and good thing is this is with Android 10 . Whatever the name of this update like beta 5 or etc it doesn't matter to me . I purchased device in mid of 2018 and now at the end of 2020 asus is still providing latest security patch update and provided 2 major os updates .438 build is good and stable enough for me to use it as a daily drive. Sound is also good in 438 build. Request to asus , please bring so called Android 10 stable update to max pro M1 .All users are waiting for that ,just like me.I tried almost every custom rom for max pro M1 like PE, havoc ,Corvus , RR, ION ,bliss , colt , nusantara , evolution X , paranoid etc in last six months.But every time when asus give us update definitely all users preference is to use stock rom latest update rather than custom.This is the importance of stock rom updates bcz of security issues , stability issues of custom roms etc.
hopefully if not this month but maybe January.. asus could give us the stable update for max pro m1 😁 Merry Christmas from Philippines 🇵🇭
1. Es Update me Network ka icon Show nahi kar raha hai backup restore karne par bhi
2. Sound problem bhi hai bluetooth year Phone sound bhi slow hai
I want stable android 10 update for Zenfone M1 it won't be beta that much
I have install android 10 build .438
