Android 10 emergency calls problem in Turkey (17.2018.2012.438 ) ZB 602 KL
Hello  Christine_ASUS, victor0_ASUS
Emergency calls problem in Turkey, the latest version on your official website was solved with WW-16.2017.2009.087. I have provided feedback for fixing Android 10 beta versions, but when I download and install the 17.2018.2012.438 version, I see that there is no fix on Android 10. Due to this problem on the Vodafone line, our Emergency Call numbers are 112 Ambulance and 155 police lines. This is a very critical issue for us, I ask for a fix in the next update.
  1. Model Name:ZB602KL
  2. Firmware Version:17.2018.2012.438
  3. Rooted or not: NOT
Comments
  • Hi friends
    Please note that the latest version of ZenFone Max Pro M1 Android 10 beta WW-17.2018.2012.438 does not fix the situation. For Turkish users, kindly remain in Android 9. I will check with the relevant team for the case and keep you updated. Sorry for any inconvenience it may be caused.
  • Asus Turkey Service with the error in the results of your labors center is a situation that arose after he conveyed Android 8. Afterwards, the android 9 beta update ending with 85 sent from your center was uploaded to my device, and after 1.5 months, the final update with 87 code was released as said.
    I am using Android 10 and I do not want to use Android 9, to fix this problem, I wrote my message to you before, you gave me your feedback that it was delivered to the relevant unit on August 19.
    I expect you to correct the mistake as soon as possible and to eliminate our unjust treatment.
Sign In or Register to comment.
