Microphone volume low for ROG PHONE 3
ajayvijay912ajayvijay912 Level 1
edited February 2021 in ROG Phone 3
  1. Model Name: asus rog 3
  2. Firmware Version: android 10
  3. Rooted or not: not
  4. Frequency of Occurrence: all the time
During every phone call, for the opposite person, my voice is very low. It's been jus a month, a purchased this phone. It really bad that this issue happens in new phone..
Hope asus team give any solution.. thank you.
Comments
  • Hi,
    I have received this feedback from few users and the same has been forwarded.
  • I have the same problem. It works fine in games and recordings so it's definitely not the hardware. It only happens during normal calls. Also if I have a headphone on and use its microphone, there are no issues.
  • I'm also facing the same issue and it's not the hardware issue . But the sad thing is we have Four microphones in our device still our audio quality is bad while calling
  • And no response 🤣🤣
    Thank God I stopped buying ASUS products
  • Same problem with me
  • DanishbluntDanishblunt Level 5
    edited January 2021
    If you have rooted device find init.d and add:
    tinymix 31 23
    tinymix 32 27
    tinymix 33 27
    tinymix 34 27
    tinymix 35 27
    then you got nice volume.
    EDIT:
    nvm this was for motorolla specifically. You need to edit system/vendor/etc/mixer_paths_cdp.xml file and look for volumes.
    Make sure you're also on the latest update because iirc ASUS had a little to aggressive noise reduction causing some issues with microphone recordings on some devices.
