Aura Lightning not working for ROG Phone 2 and ROG Delta Headphones.
Nkz
Model Name: Asus ROG Phone 2
Firmware Version:17.2040.2009.49
Rooted or not: Not Rooted
Frequency of Occurrence: Everytime
APP Name & APP Version (If your issue relates to the app): Armoury Crate
Step 1 : Connect the ROG Headset to ROG Phone 2 using the Type C cable.
Step 2: Open the mobile app - Armoury Crate (Orange Logo).
Step 3: Click on Console and swipe up to reach the "System Lighting" section.
Step 4: Click "Advanced Settings"
Step 5: Disable and re enable the slider for "ROG DELTA"
Step 6: Click "OK" for "Allow ArmoryCrate to access USB Audio"
Step 7: Get disappointed the ROG delta headset rgb is off with all the other settings still on and rbg working for Rog Phone 2.
There should not be a need for me to everytime disable and enable to give permission for usb audio and it should work and sync with mobile as it is supposed to.
ARP_ASUS
Community Legend II
Thanks for sharing the steps, let me check if possible internally and get back to you.
ARP_ASUS
Community Legend II
As per the information available. The Aura sync won't work on the delta.
For further info you can visit the below link.
https://www.asus.com/me-en/support/FAQ/1037227/
Nkz
Sure, thank you! But I don't think that helped at all.
