Battery draining very quickly even not using the phone.
- Model Name:Rog phone 3
- Firmware Version:
- Rooted or not:no
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
We need you to solve this problem which has occurred after new update. Please release new update as soon as possible. Or please take this phone back and return our money because this phone is not worth of 50 K. And the black crush issue is worse not able to see anything in the dark videos. Phones which are cheaper then this have a better display.
Comments
Hi, when you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Olá também estou com o mesmo problema. Comprei este telemóvel exatamente pela bateria e a mesma nao dura mais do que o meu antigo telefone (huawei p30 pro)
.99 update. Over 5 days battery.
OK I will do as u said
U should share the screenshot as well to show that stand by time. Or else everyone will be wondering like I am.
Ohh my blind eyes. 3days stand by.
Battery drains more than 5 percent when kept idle overnight...
As you asked. This screen shot is after updating. 122 December update.
