IDLE BATTERY DRAINING ISSUE IN ASUS ZEFONE MAX PRO M1
- Model Name:max pro m1
- Firmware Version:0.87
- Rooted or not:not
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Comments
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
