[Solved] How to downgrade ZenFone Max Pro m1 Android 10 Beta 4 to Oreo Android 8
Can I get android 10 beta 4 to Oreo in max pro m1 by sd card method. (Sdcard method– keep Oreo software in sd card without any folder, go to the recovery mode, select the <apply update from external storage> select the software file and flash the file.
2
Best Answer
Christine_ASUS mod
https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB602KL)/HelpDesk_BIOS/
No, downgrade file is different from OTA file. For ZB602KL, you can only downgrade from Android 10 to Android 9 with downgrade file Version MaxProM1_downgrade_to_9, yet you can not install OTA file with downgrade procedure and claim it as firmware downgrade. There is no downgrade file from Android 9 to Android 8.
6
Comments
No,u have to reinstall os through pc
Please provide link for Last build of Android Oreo. Can I downgrade from Android Pie to Oreo with that build?
https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZB631KL/UL-ASUS_X00T-WW-15.2016.1902.340-user.zip
He is saying that he want downgrade to A8
As I mentioned above, there is only downgrade file for Android 10-Android 9. You may ask the repair center to check if they can help or not even you are willing to pay for the software repair fee. Personally, I don't suggest users to use Android 8 because of the compatibility between firmware version and app version. Sorry for any inconvenience it may be caused.
Call recording apps aren't working properly on Android 9 or Later. Can Asus bring call recording feature to ASUS phones
As we r on stock rom , so its depends on google whether they will provide call recording feature or not,
Untill Google roll out this feature, use the default system sound recorder to record calls. It will not work with Bluetooth headsets I think.
Can I downgrade to Android Oreo from Pie by flashing a recovery ROM? Please confirm that. Will it work? It's all for call recording only.. Call records aren't working on Android Pie and 10
Call recording works on Android 10. The inbuilt sound recorder records calls too. Just tried one call ago.
Why even use call recording apps when stock sound recorder app can do job with a better UI.
If you really want to revert to oreo check asus flash tool thread on xda.
automatic call recorder I'm talking about actually.
Those apps clearly declared in their descriptions that Android 10 doesn't support the ACR apps due to changes done by Google. Possibly to bring their own.
Read the intro.
Update my phone
@Christine_ASUS See This Image Asus Zenfone Max Pro M1 Support Video Calling In Oreo But Asus Remove This We Need Video Calling
Google is the reason
Hey @Christine_ASUS,
How are you doing....
What is your job...is that just to do copy and paste in replies!
What are you updating to your developers team.
Arey they working or Just sleeping in homes...
If you have vacancies please do recruit some good team.
What sin does asus users did.
Dont you value their emotions......
How many days we have to wait for you shitty updates. Its been 1 year, android 11 is coming but your team not providing a stable version of Android 10.
Very very Naish company...just realised some shitty companies are also therein society which do not value customers.
Firstly the company have to develop in many aspects... Update yourself first!
#Asuszenfonemaxprom1
#Asuszenfonemaxprom2
#PluckAsus
Hope they will consider this and develop themselves..!🙌
Hi pooskurinaresh587
Thank you for your asking. For further information related to any firmware update, please stay tuned to our social media channels or visit our Asus support website.
#ZB602KL Firmware Spot_Asus Support
Thank you for your continued support and patronage.
