Asus Zenbook 14 UX434FLC Battery Problem
eliaz.brumereliaz.brumer Level 1
edited December 2020 in ZenBook
just bought this laptop - and from the beginning low battery capacity - held for less then 4 hours.
restarted the bios and AC adapter in the device manager - nothing help....
sent it to repair - they changed the battery - work fine for several hours and then - low capacity - held for less then 4 hours.
when charging - the led turn to white in around 98% and when it reach to 99% - the display for time for full charged stuck and it can remain on 5 minutes for more 30 minutes or so. If restart the AC adapter in the device manager while its stuck on the 5 minutes - time will update but will stuck again.
any idea?
Comments
  • Hello Eliaz,
    May I know your BIOS version and may you double check if your Windows updates have all been completed?
    And may I know if there is a gap between the battery time indication and the reality battery usage?
    Please kindly understand that when the battery is almost full charged, the charging will be slowed down.
  • all the windows updates have been completed and the time indication is variable and change evert 10 minutes. but in reality the longest time its held was 3.5 hours from full charge until it turn off.
  • Hello Eliaz,
    Thank you for the information.
    In this case, we would need to dig in more on your settings when you have 3.5 hours battery usage.
    Your device is i5 or i7 version?
    What kind of program were you using? was the screenpad on?
    What's the screen brightness, volume, Wifi, bluetooth...
    you may also check in task manager to see if there is any specific function that is consuming more power than expected.
  • it is i7, 10th generation
    screen pad is off and also keyboard light.
    CPU use less then 7%, no specific program.
    use most for zoom meting and office
  • Hello Eliaz,
    I see. Thank you for the information.
    Let me find a device and try to simulate the same scenario as your description.
    You may try to adjust some of the settings as well.
    Another thing is which battery mode did you set to ?
    in MyASUS and Windows Power options.
  • and as you can see from the picture - 60% - 3 hours and 25 minutes left - and of course this is virtually,
  • we cant give gaurantee of battery stay for 6 hours or any hours mentioned in site while purchasing any laptop.
    reasons are very simple.
    1 We use multi core function with heavy features of windows os with running lots background applications.
    2 Normally laptop users 32WH or 38WH batteries , only fewmodels have 72WH but with high performance dedicated video graphics card.
    3 In many cases , while working with windows os with dedicated gpus , gpus gets automatically enabled ad active throughout the running os , so the battery power decreases without knowledge
    if you we use LIGHT Operating system without complecated running background services and background running applications , then definately we can get more battery life
  • so on the ASUS official web - it says that the battery hold for 50 hours - and that why I bought the computer:
    as you can see when it decrease to 40% after 30 minutes - there is only 1 hour left.
    I have a 5 years old asus zen book that have the same program and systems - and still hold for more then 8 hours on battery. I worked simultaneous on both the laptop and the new didn't hold. I don't know if this a problem in my laptop or it is problem with model - but defiantly there is a problem!!!! and I would be glad to get a solution.
  • edited November 2020
    50WHrs means battery capacity , not battery will work 50H .
    In website , asus does not mentioned in words like , this laptop will hold battery power upto 50Hours in single charge.
    in my laptop, battery capacity is 38WH = 38Watthour , not Working Hours .
    download batteryinfoview.exe app from below link
    and unzip file, execute batteryinfoview.exe , post the screenshot .
    for example
  • here it is
  • I seen the picture, battery is too good and new..
    so I suspecting in windows OS . Before I give some ideas, I want to know few answers from you.
    1. which brand and model number processor is embedded in your laptop
    2 which bios firmware version is installed in laptop.
    3 Did high end dedicated graphics card is installed on laptop motherboard,if yes means name of GPU and size of GB
    4 which edition and version of windows 10 is installed in laptop
  • the battery is new due to two reason - it is a new laptop - 1.5 month and the second is that the battery was replace 2 weeks ago by ASUS lab technician - as the battery barely worked - and they found out that it was swollen and had to changed it. So My though that it may be a problem in the motherboard or something that control the battery.
    here all the information - if you need anything else just tell me where to find it
    that you
    OS Name Microsoft Windows 10 Pro
    Version 10.0.18363 Build 18363
    Other OS Description Not Available
    OS Manufacturer Microsoft Corporation
    System Name LAPTOP-M635S51R
    System Manufacturer ASUSTeK COMPUTER INC.
    System Model ZenBook UX434FLC_UX434FL
    System Type x64-based PC
    System SKU
    Processor Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz, 2304 Mhz, 4 Core(s), 8 Logical Processor(s)
    BIOS Version/Date American Megatrends Inc. UX434FLC.306, 15-May-20
    SMBIOS Version 3.2
    Embedded Controller Version 255.255
    BIOS Mode UEFI
    BaseBoard Manufacturer ASUSTeK COMPUTER INC.
    BaseBoard Product UX434FLC
    BaseBoard Version 1.0
    Platform Role Mobile
    Secure Boot State On
    PCR7 Configuration Elevation Required to View
    Windows Directory C:\WINDOWS
    System Directory C:\WINDOWS\system32
    Boot Device \Device\HarddiskVolume1
    Locale United States
    Hardware Abstraction Layer Version = "10.0.18362.1171"
    User Name LAPTOP-M635S51R\eliaz
    Time Zone Eastern Standard Time
    Installed Physical Memory (RAM) 16.0 GB
    Total Physical Memory 15.8 GB
    Available Physical Memory 12.0 GB
    Total Virtual Memory 18.7 GB
    Available Virtual Memory 14.4 GB
    Page File Space 2.88 GB
    Page File C:\pagefile.sys
    Kernel DMA Protection Off
    Virtualization-based security Not enabled
    Device Encryption Support Elevation Required to View
    Hyper-V - VM Monitor Mode Extensions Yes
    Hyper-V - Second Level Address Translation Extensions Yes
    Hyper-V - Virtualization Enabled in Firmware Yes
    Hyper-V - Data Execution Protection Yes
    IRQ 109 I2C HID Device
    IRQ 109 Microsoft ACPI-Compliant System
    IRQ 16 Intel(R) Dynamic Tuning Processor Participant
    IRQ 16 Intel(R) Serial IO I2C Host Controller - 02E8
    Memory Address 0xC3000000-0xC3FFFFFF NVIDIA GeForce MX250
    Memory Address 0xC3000000-0xC3FFFFFF Intel(R) PCI Express Root Port #5 - 02BC
    Memory Address 0xA0000000-0xDFFFFFFF PCI Express Root Complex
    Memory Address 0xA0000000-0xDFFFFFFF Intel(R) UHD Graphics
    Memory Address 0xB0000000-0xBFFFFFFF NVIDIA GeForce MX250
    Memory Address 0xB0000000-0xBFFFFFFF Intel(R) PCI Express Root Port #5 - 02BC
    Name NVIDIA GeForce MX250
    PNP Device ID PCI\VEN_10DE&DEV_1D52&SUBSYS_150F1043&REV_A1\4&1D68CD4A&0&00E4
    Adapter Type GeForce MX250, NVIDIA compatible
    Adapter Description NVIDIA GeForce MX250
    Adapter RAM (2,147,483,648) bytes
    Installed Drivers C:\WINDOWS\System32\DriverStore\FileRepository\nvam.inf_amd64_c436e4f86f7beadc\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvam.inf_amd64_c436e4f86f7beadc\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvam.inf_amd64_c436e4f86f7beadc\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvam.inf_amd64_c436e4f86f7beadc\nvldumdx.dll
    Driver Version 26.21.14.4294
    INF File oem89.inf (Section012 section)
    Color Planes Not Available
    Color Table Entries Not Available
    Resolution Not Available
    Bits/Pixel Not Available
    Memory Address 0xC0000000-0xC1FFFFFF
    IRQ Channel IRQ 4294967274
    Driver C:\WINDOWS\SYSTEM32\DRIVERSTORE\FILEREPOSITORY\NVAM.INF_AMD64_C436E4F86F7BEADC\NVLDDMKM.SYS (26.21.14.4294, 22.19 MB (23,272,176 bytes), 12-Oct-20 22:52)
    Name Intel(R) UHD Graphics
    PNP Device ID PCI\VEN_8086&DEV_9B41&SUBSYS_150F1043&REV_02\3&11583659&1&10
    Adapter Type Intel(R) UHD Graphics Family, Intel Corporation compatible
    Adapter Description Intel(R) UHD Graphics
    Adapter RAM 1.00 GB (1,073,741,824 bytes)
    Installed Drivers C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a15faa87237524bb\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a15faa87237524bb\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a15faa87237524bb\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a15faa87237524bb\igd12umd64.dll
    Driver Version 26.20.100.7870
    INF File oem101.inf (iCML_w10_DS section)
    Color Table Entries 4294967296
    Resolution 1920 x 1080 x 60 hertz
    Bits/Pixel 32
    Memory Address 0xC2000000-0xC2FFFFFF
    I/O Port 0x00004000-0x0000403F
    IRQ Channel IRQ 4294967273
    Driver C:\WINDOWS\SYSTEM32\DRIVERSTORE\FILEREPOSITORY\IIGD_DCH.INF_AMD64_A15FAA87237524BB\IGDKMD64.SYS (26.20.100.7870, 23.45 MB (24,591,928 bytes), 12-Oct-20 22:56)
    Name Citrix Indirect Display Adapter
    PNP Device ID PCI\VEN_5853&DEV_1003\1&79F5D87&0&03
    Adapter Type Not Available, Citrix Systems Inc. compatible
    Adapter Description Citrix Indirect Display Adapter
    Adapter RAM Not Available
    Installed Drivers Not Available
    Driver Version 12.40.44.247
    INF File oem43.inf (ViddDev_Install.NT section)
    Resolution 504 x 1000 x 50 hertz
    Bits/Pixel 32
    Driver C:\WINDOWS\SYSTEM32\DRIVERS\WUDFRD.SYS (10.0.18362.1, 291.00 KB (297,984 bytes), 18-Mar-19 23:44)
  • thanks for the detailed information
    intel i7-10510U CPU , intel UHD 620 builtin gpu
    dedicated nvidia geforce mx250 2gb vram
    I would recommend you , upgrade the windows 10 1903 version to windows 10 20h2 build no 19042.572 and update to 19042.630
    but you installed old intel gpu driver and old nvidia dch gpu driver .
    you should install new intel gpu dch driver 27.20.100.8935 stable from below link
    you should install new nvidia gpu dch driver 27.21.14.5730 stable from below link
    and then after completing upgrade and installing new drivers , then restart windows ,
    connect the windows to internet , then execute below commands in cmd prompt with admin rights
    MD D:\Temp
    Sfc.exe /Scannow
    Dism.exe /Online /ScratchDir:D:\Temp /Cleanup-Image /SPSuperseded
    Dism.exe /OnLine /ScratchDir:D:\Temp /CleanUp-Image /StartComponentCleanup /ResetBase
    Dism.exe /OnLine /ScratchDir:D:\Temp /CleanUp-Image /AnalyzeComponentStore
    Dism.exe /Online /ScratchDir:D:\Temp /Cleanup-Image /StartComponentCleanup
    Dism.exe /OnLine /ScratchDir:D:\Temp /CleanUp-Image /CheckHealth
    Dism.exe /OnLine /ScratchDir:D:\Temp /CleanUp-Image /ScanHealth
    Dism.exe /OnLine /CleanUp-Image /ReStoreHealth
  • go to below site , download CSME_Version_Detection_Tool_Windows 4.0.1.0 windows version , unzip the file
    https://downloadcenter.intel.com/download/28632/Intel-Converged-Security-and-Management-Engine-Version-Detection-Tool-Intel-CSMEVDT-
    then execute CSME-Version-Detection-Tool from DiscoveryTool.GUI folder , post the scrrenshot
    for example
    in picture , green line should shown , if red comes means , processor is still under vulnerable
  • thank you,
    I will do it and let you know.
    I appreciate all the help
  • so I got that the system is vulnerable = what should I do
    you must flash latest intel management engine firmware version 14.0.46.1431 to intel i7 10510U processor by available flashing tool . Flashed firmware is permanent it cant be downgraded or deleted from processor , but it can upgraded to next version firmware .
    Flashing of incorrect firmware SKU makes the laptop Dead,
    but there are four SKU based above firmware version
    say
    Intel CSME 14.0 Consumer PCH-H A Firmware v14.0.46.1431
    For Comet Lake H systems which run CSME Consumer H A v14.0
    Intel CSME 14.0 Corporate PCH-H A Firmware v14.0.46.1431
    For Comet Lake H systems which run CSME Corporate H A v14.0
    Intel CSME 14.0 Consumer PCH-LP B,A Firmware v14.0.46.1431
    For Comet Lake LP systems which run CSME Consumer LP B,A v14.0
    Intel CSME 14.0 Corporate PCH-LP B,A Firmware v14.0.46.1431
    For Comet Lake LP systems which run CSME Corporate LP B,A v14.0
    Really i cant judge which SKU edition PCH - H or PCH- LB A is suitable to your processor .
    for my vivobook 15 R542UQ-DM153 with Bios X542UQ model , suitable firmware is
    Intel CSME 11.8 Consumer PCH-LP C NPDM Firmware v11.8.81.3781,
    i took own risk, i found the correct firmware in the non asus website , i downloaded and then i flashed to without problems .
    i downloaded the firmware
    https://www.win-raid.com/t596f39-Intel-Management-Engine-Drivers-Firmware-amp-System-Tools.html
    but for your model processor is doubt , so onething you can do, send an email to asus Research development team via email
    security@asus.com
  • OK,
    I will send them an email.
    Is this can explain the battery problem?
    what that is mean that he system is vulnerable
  • system refers to processor it's can be attacked by hackers , Intel Inc already released firmware to solve this , firmware must be released by laptop manufacturers to respective models of laptops.
    vulnerable processor should not be used for work..
    some times battery problems can be solved by flashing intel ME firmware.
    sometimes by adjusting the windows os , battery draining problems can be solved
  • I understand...
    So I will monitor the battery after all the update... and I will let you know if the problem has been resolved
