zenfone 6,6z,7,7pro front camera solution
joe_hipjoe_hip Level 1
edited December 2020 in ZenFone 6
  1. Model Name:
  2. Firmware Version:
  3. Rooted or not:
  4. Frequency of Occurrence:
Comments
  • After Androis 10 update, front camera uses proximity sensor for opening
    Solution is easy: remove screen protection (glass, plastic or other cover material can block the proximity sensor
    Proximity sensor is located on next to earspeaker on the right
    Make sure is clean
    Sorry for my bad english
    Hope is working for you
    Best of all!
