Overheating problem
GODPOSEIDONGODPOSEIDON Level 1
edited December 2020 in ROG Phone 3
The phone is heating up to 46°c while playing pubg even in lowest brightness , 60 fps, Xmode off. What will be the temperature of the phone while using it in 144 hz and full brightness
Comments
  • Meanwhile the Samsung reaches over 80c while throttling and you're complaing about 46c, do you even do research before writing anything?
  • Hi GODPOSEIDON,
    The device temperature may vary depending on the settings and ambient temp around you.
    Also, if you have multiple process running behind game even that could affect the device temp.
    Gaming phones with different settings and ambient temp can reach around 46 when you are gaming and using App for longer period of time.
