BATTERY DRAIN
kumaresan
Model Name:ASUS ZENFONE MAX M1
Firmware Version:WW-15.00.2007.122
Rooted or not: NOT ROOTED
Frequency of Occurrence:DAILY
APP Name & APP Version (If your issue relates to the app):BATTERY
RECENTLY, MOBILE NETWORK STANDBY battery consumption is increasing rapidly. At the end of day, it is showing around 24% percent. I have to charge my mobile 3 times per day due to battery drain. Any suggestions for the battery drain and any information about the update because the last update received was around the end of JULY month.......
victor010
Zen Master III
Hi, Please follow below steps may improve battery backup:
1. Enable “Power saver” (Settings > Power management)
2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
3. Adjust sleep time and brightness (Settings > Display)
4. Boost memory when you see memory consumption is high with no app running,
5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
you may also follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
