Laptop adapter making buzzing sound please help....
- System: Asus Vivobook M409DA
- Battery or AC:
- Model:
- Frequency of occurrence:
- Reset OS:
- Screenshot or video:
Detailed description:
Uff, I am so scared right now because the charger is making buzzing noises whenever I plug my laptop. I have no problems with charging but When I take ears close the adapter I can hear some buzzing noise. If you have same model and you are not facing this issue please let me know so that I can immediately call for Asus Support Thanks for reading.
Comments
Hello alokpawar404,
The buzz sound is close to the power jack to laptop or the wall socket?
Have you tried to plug to another socket?
Thanks for replying. I don't really the know the names of charger and stuff. But the adapter which connects the powercable and the cable connecting to the laptop has the buzzing sound.
This middle adapter part. Inside that...
Hello alokpawar404,
You mean the square one? If so, that's pretty normal to have some electric buzz.
If it's really obvious and annoys you, you can bring it our service center for double check.
If it is normal then no worries. thanks 😃
