Problems with android beta 4 in max pro m1.
I am having heating issues with my Asus zenphone max pro m1 even only 2 to 3 apps are running in the background but my mobile is getting hot and sometimes facing call volume issues and network problem.so please fix the issues and kindly roll out android stable 10 update.i don't know how many android beta for 10 will you provide before giving stable android 10.
Comments
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
