MAX PRO M1. Phone Upgraded Manually to Android 10. But the wifi Speed is low when Compared to Pie 9
Dear Developer,
I have updated Android 1O Version (Build No: WW_Phone-17.2017.2008.432-20200903) in my mobile Asus Zenfone Max Pro 1.
After I upgraded, I noticed that the WIFI Speed reduced (50MBPS to 15 MBPS). Now I'm able to get 15MBPS Speed Only. I Cross Checked with Another mobile with Same configuration Which was not Upgraded to 10. That phone speed shows 50MBPS.
Something happened in 10 Version Upgraded. Can you look into this issue and resolved ASAP.
0
Comments
Hi srinivasarajesh.k
Please avoid overlapping thread or message, which may disturb the mods and the users to solve the issue. Kindly refer to the same thread as below
