Battery issue
edited November 2020 in ZenFone 5 Series
  1. Model Name:zenfone 5z
  2. Firmware Version:10
  3. Rooted or not:not
  4. Frequency of Occurrence:50
in this new update battery drained quickly in about 2 to 3 hours.
Please provide solutions.
Comments
  • Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
    1. Charge the battery to 100% & use as per your normal usage pattern
    3. settings => Battery => Check the screen & share the same
    Please follow below steps may improve battery backup:
    1. Enable “Power saver” (Settings > Power management)
    2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
    3. Adjust sleep time and brightness (Settings > Display)
    4. Boost memory when you see memory consumption is high with no app running,
    5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
    6 . Check the following article for more information: https://www.asus.com/in/support/article/604/
  • It's show only 3 hour screen on time.
  • @victor2020 @ServiceC_ASUS and asus team no reply yet.
  • GeraGera Level 1
    3 hrs? I Get 2:30 max. Normal is 4
