Battery drain fast
- Model Name: rog phone 3
- Firmware Version: no firmware version highlight
- Rooted or not: no
- Frequency of Occurrence: regular
- APP Name & APP Version (If your issue relates to the app):
Comments
Hi, when you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Make sure you are on latest software version which is .78, you can check by
Go to setting => About => Software information.
