WORST MOBILE BATTERY I HAVE NEVER SEEN THIS TYPE OF BATTERIES.SO WORST BRAND AND BATTERY POWER AND P
edited November 2020 in ZenFone Max Pro Series
Don't buy asus brand mobiles
  1. Model Name:max pro m1
  2. Firmware Version:0.87
  3. Rooted or not:not
  4. Frequency of Occurrence:
I charged my mobile to100%and without doing anything I kept my phone and after morning when I wake up when I saw my mobile battery reduce to92% 8%percebtage decreased without any usage.worst battery plz don't buy asus brand mobiles.
Comments
  • Hi, Please follow below steps may improve battery backup:
    1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
    2. Adjust sleep time and brightness (Settings > Display)
    3. Boost memory when you see memory consumption is high with no app running,
    4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
    5. Check the following article for more information: https://www.asus.com/in/support/article/604/
    You may also follow the below steps:
    1. Clear system cache.
    2. Try the same under safe mode:
    Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
    3. If still you face the issue
    factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
    4. Last option would be to visit the service center to have
    a check. Locate here: https://www.asus.com/in/support/Service-Center/India
