ASUS max pro M2 Reverse charging Popup issue. When I keep it for charging I can access
Please tell us some basic information before asking for help: ASUS max pro M2 Reverse charging Popup coming repetitively and I can't access my phone :(. When I keep it for charging I can access message will not come once I remove charging then again same issue. Fed-up with this message :(
- Model Name: ASUS ZENPHONE MAX PRO M2
- Firmware Version: MAX PRO M2
- Rooted or not: lot of time rebooted but issue not solved
- Frequency of Occurrence: always if I don't charge mobile
- APP Name & APP Version (If your issue relates to the app): Reverse charging Popup issues.
Comments
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
