Random Shutdown issue in Max Pro M1
  1. Model Name: Max pro M1
  2. Firmware Version: 432 ( Beta 4)
  3. Rooted or not: NO
  4. Frequency of Occurrence: Maybe Once in a week
Hello @Christine_ASUS
First of all I would like to inform you that I'm willing to send my device log if that's needed by you guys in any manner for further investigation.
I'm rarely facing the problem of Random shutdowns. Currently I'm on the 432 build. In this build this issue happened only once ( thats today)
While I was on the 424 build I faced this issue multiple times( more than 5 times). Let me try to explain how my device gets into power of mode in build 424. While in use, my device gets freezed and for like 10 to 20 seconds nothing happens. Then all of a sudden screen goes blank. Then in order to turn my device back on I had to press the power button more than the usual time. I'm not sure but I think the network has something to do with this issue. If I'm right I notice my signal bars behaving strangely during the phone gets freezed ( might be I'm wrong)
I used build 429 for just 2-3 days and hence I did not face this problem.
In build 432 I'm not sure how my device got into power of mode. I plugged in my charger and laid my phone on table as usual and left my room. But, after 15 minutes when I got back what I could see is that my device was in power off mode. Also not even a single percentage of charging was done.
NB: After I turn on my device everything works perfectly.
Like I said earlier I'm willing to send you my device log if needed. Kindly send a PM for the same.
Thanks!!!
Comments
