Max pro m1: Audio bugs android 10 beta,build 432
- Model Name:Max pro m1 (ZB602KL)
- Firmware Version:432 global (WW)
- Rooted or not:no
- Frequency of Occurrence:-
- APP Name & APP Version (If your issue relates to the app):-
Bug report:
- If i listen music with my music player,and listen youtube web together,sound quality drop,no bass,very flat sound.
- Sound volume from 70% to 100% not difference.
- RAW image capture not work
- Sound quality need more improvement and balancing and tuning.
Comments
exact same issues
Hi friends
Some issues are already under discussion in other threads, please go to the link I mentioned to avoid overlapping information
1. What is your music player app? Do you encounter the same issue with other apps + youtube web? If you use youtube app, do you encounter the same situation?
2 & 4. Sound. Please refer to the link as below
https://zentalk.asus.com/en/discussion/comment/118333
3. RAW image capture. Please refer to the link as below
https://zentalk.asus.com/en/discussion/36420/
Besides, because the issues you reported are all related to AUDIO, please avoid overlapping thread or message, which may disturb the mods and the users to solve the issue...
