Rog phone 2 battery and heating problem after updating
- Model Name: ROG PHONE 2
- Firmware Version: 17.0240.2009.47-0
- Rooted or not: NO
- Frequency of Occurrence: Constantly
- APP Name & APP Version (If your issue relates to the app):
0
Comments
Hi
Ifter updating my phone to the latest rom - 17.0240.2009.47
I have the following problem:
Cpu stuck on maximum frequency at 2.95 mhz
The phone over heats and the battery drain much faster.
Questions:
Can i use my phone till next update or will be damaged?
When will be update to fix this issue?
And the last question is WTF ASUS?
To the suggestions (and the main post for this problem)
You can find some useful suggestions from here in the below post to help minimise the effects of the problem. I would still recommend trying to minimise the problem rather than using the phone as it is. (For example, if you are playing games for a long period of time)
Update next week confirmed by moderator:
The next update according to moderatorshere is next week.
Yes I have observed the same above... my phone is heating..battery is draining faster than normal and is taking a long time to charge
