[call disconnect tone] ZENFONE MAX PRO M1 (BETA432 ANDROID 10)
There's no call disconnect tone upon disconnecting the call while in vibration or silent mode, but there's a disconnect tone in general mode i.e, while not in silent or vibration!!
1
Comments
Hi dibyarupprk2011
Thank you for your asking. To avoid any misunderstanding, do you mean the one second tone appears right after disconnected from the call?
Firstly am glad that you replied
Yes, in android 10 beta 432 the tone that that occurs after disconnecting the call is hearable only when the phone is in general mode (i.e, while not in silent or vibration) but, not hearable in silent or vibration mode
One more thing: in android 10 beta 432 we randomly get wallpaper turning black while using android 10 gesture to go to home or recent apps
The video related to the wallpaper turning black
Hi dibyarupprk2011
I have forwarded the information of call disconnect tone to the relevant department. We will keep you updated and your consideration will be very much appreciated.
For any other issue, please open a new thread for further discussing. Please check if the same issue has been reported by other users before posting the new thread.
Ya..the same issue is being reported by others too in some other threads.. i didn't want to have more and more threads so mentioned in this only.. you can see the screenrecord i have given above!
Please leave your comment and information in the thread of the same issue reported by other users then. Thank you. :)
Mentioned, kindly check it!
Hi dibyarupprk2011
The disconnect tone in silent/vibration mode is a normal behavior of Android 10 AOSP system. Sorry for any inconvenience it may be caused.
