Rog Phone 3 battery issue
ZenoZeno Level 1
edited October 2020 in ROG Phone 3
Smartphone: Asus Rog Phone 3 16 GB
Firmware version: 17.0823.2008.70
Hello,
I'm posting this message hoping that a moderator or someone else can give me some information regarding my issue.
The "slow charge" function of my Asus Rog Phone 3 seems to be activated all the time.
Whether I activate it or not, it doesn't change anything.
Initially, the slow charge did not work when I activated it, the phone charged in a classic way in "fast" mode about 1 hour 30 minutes to go from 0 to 100%.
I believe that since the firmware update .70, the phone is stuck in slow charging mode because it takes more than 1h30 to go from 60% to 100% and to go from 8% to 100% it takes more or less 2h43 min .
I tried with different charger, and use the second port of Rog Phone 3 but nothing changes.
I also completely reset the phone but nothing has changed.
The "load limit" function also does not work. Before the .70 firmware update it was working pretty well.
It's been a little less than 2 weeks since I have the phone, bought directly from the Asus Shop, I don't do anything too "intensive" with it, and yet this battery problem is present and also hinders my comfort.
Could a future update fix this problem or is there already a solution?
Thanking you in advance.
