Asus zenfone max pro m1 battery drains
- Model Name:ASUSX00TD/ZB601KL
- Firmware Version:9 PIE
- Rooted or not:not
- Frequency of Occurrence: continue
- APP Name & APP Version (If your issue relates to the app):
In Asus zenfone max pro m1
phone is continuing to drain battery since last updated on sept 10 == I have tried calibration also like use untill switch off then use charger to charge a 100% or until LED turns green and so turned it on but still the problem has not resolved.==if anyone facing same issue please comment===================================
0
Comments
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
I'm facing the problem of battery draining problem in idle screen also...about 2-5 percent battery goes down when the phone is switched on and kept aside without being touched
