Battery drain Fastly
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Asua zenfone 5z
zs620 kl
No rooted
Battery Drain fastly when received updated 5 august update veesion my battery drian automatically 20 to 25 % in night and backup is not more sufficient as compared old
0
Comments
Plz asus fix this problem battary drain fastly and backup is not more sufficient as old days
Hi, please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
you may also follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/Indi
the battery is still draining rapidly. it's a software problem and you still say factory reset. Please fix this software problem now
hiii i m not gotted latest update which release date 17 September
you received update or no plz tell me?
As a temporary solution, try battery saving app such as Greenify..
