Max pro m2 idle battery drain when fingerprint sensor is turned on.
Max pro m2 battery drain when fingerprint sensor is turned on(only when phone is in idle condition) . Changed software and sensor but of no use.
Comments
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Also, kindly share with us the firmware version of the device.
There is no unsual battery drain when phone is in use. Also no problem with the SOT. Battery graph is not detecting ideal battery drain.
will u please share screenshot of
running services and chached process from developer option
ur quickstep launcher is using too much ram
turn off notification dots in quickstep
Okay. But there is no battery drain when i turn off the fingerprint sensor.
Okay. But there is no battery drain when the fingerprint sensor is turned off.
Yeah, for this bug, i can confirm when fingerprint on there's bug that when phone in idle it always drain battery and when i turn off the fingerprint there's no drain battery when idle... I and for two month i turn off the fingerprint my battery backup is good when idle... And one more when fingerprint on, around the fp get more heating than usual thats why i turn off the fp and its more "normal"
I changed my fingerprint sensor because of this problem. And was good for three months but again i am faced the same issue.
are u on .097 update
I m on the latest version. I am facing this issue for more than 6 + months.
