Battery
Boyy..Boyy.. Level 1
edited October 2020 in ZenFone 4 Series
Why my hp automatically off..battery 70%.?
Comments
  • edited September 2020
    Hi Boyy..
    Thank you for your asking. Kindly try some stay-at-home troubleshooting tips below:
    1. Is there any zone heating up while using/idling?
    2. How long has the battery been used?
    3. Enter "Safe Mode" and leave a 100%-charged phone in sleep(idle) mode in a night, then provide me the screenshot of
    ①Setting>Battery
    ②Setting>Battery>3 dots on the top"Show app usage"
    If the battery works well in "Safe Mode", please check on any disturbance from the installed 3rd party Apps.
    4.  Also, please try "the Factory Reset"
    Settings>System>Reset options>Factory data reset
    Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
    For more information, please refer to the links below
    https://www.asus.com/support/FAQ/1009546/
    https://www.asus.com/support/FAQ/1009547/
  • Have you tried updating the BIOS and the Chipset drivers to the latest version (Use the Official HP website for drivers and downloads)
