Max pro m1 After 0.87 update , battery draining issue
Asus zenphone max pro m1
4gb
64gb
2 am my battery present is 70% but i seen my phone at 8 am battery is 40% ,30 % of the battery was drained without any use
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
0
Comments
Same as mine
6 gb variety
After any software update, Factory data reset is must.
Do it and get revert back
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
