[200828] ZenFone Max Pro(M2) ZB631KL_RU_16.2017.2009.97
【Version】
16.2017.2009.97
【Model Name】
【Release Date】
2020/09/10
Since the server pushes update notice to different serial numbers by batches, it may take some days for you to receive the FOTA notice. Thanks for your patience. You may tap “System updates” in [Settings] >[System] to check if there is new firmware available. Or, you can also try to manually update firmware by referring to the following link.
How to update firmware on my phone?
【Release Note】
- Updated Android security patch
- Update GMS version
0
