WW-16.0615.2006.131 Battery issue
mmSendalmmSendal Level 1
edited October 2020 in ZenFone 5 Series
  1. Model Name: ZE620KL
  2. Firmware Version:  V16.0615.2006.131 WW
  3. Rooted or not: Not Rooted
  4. Frequency of Occurrence: Always
Hello, I've been using  V16.0615.2006.131 since its release. But it screwed my phone up. Very poor battery, always heating and low performance. Are you facing same problems? Is it because of my installed apps?
Normal Usage:
Temp: Avg. 50 degrees C
Battery: 4 hrs of Screen on Time
Before 2006:
Temp: 35 degrees C
Battery: 6,30-7 hrs of Screen on Time
Comments
  • edited September 2020
    Hi mmSendal
    Thank you for your asking. Kindly try some stay-at-home troubleshooting tips below:
    1. Enter "Safe Mode" and leave a 100%-charged phone in sleep(idle) mode in a night, then provide me the screenshot of
    ①Setting>Battery
    ②Setting>Battery>3 dots on the top"Show app usage"
    If the battery works well in "Safe Mode", please check on any disturbance from the installed 3rd party Apps.
    2. Also, please try "the Factory Reset"
    Settings>System>Reset options>Erase all data(factory reset)
    Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
    3. Is there any zone heating up while using/idling? How long has the battery been used?
    For more information, please refer to the links below
  • Sorry for late response and thank you for your immediate response. I tried safe mode, and my problem was solved, but not 100% solved. Looks like it's something about my installed apps. Screenshot is in Turkish but here's the translate:
    5 sa. 57 dk : 5 hours and 57 minutes ("sa." is "hours" and "dk." is "minutes")
    Ekran: Screen, Android sistemi: Android System, Messenger: Facebook Messenger, Telefon Boşta: Idle, Sist Arayüzü: SystemUI
    The sum of percentages are still 64%, which isn't correct since I have 6% left which means I used 94%. Does it mean there is 30% loss for no reason?
  • Hi mmSendal
    Thank you for your reply. To solve the compatibility between the firmware and the third party apps, kindly try some stay-at-home troubleshooting tips below:
    1. Because your firmware is the latest version, please try update the apps to the latest version.
