Sound problems with bluetooth headphones.
- Model Name: ASUS_1003DD
- Firmware Version: WW_17.0823.2007.58
- Rooted or not: No
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Wheezing and stuttering appear in the Sennheiser CX 7.00BT bluetooth headphones, regardless of the player or content, and if you restart the phone, the problem disappears for a while.
I can't check the operation of other bluetooth headphones, but if you connect 3.5 wired headphones via a USB-C to 3.5mm adapter, then everything is fine with sound.
If you connect the Sennheiser CX 7.00BT to other phones, then the sound is also fine, the problem is not with the headphones
Comments
Everything is ok through external speakers too.
I will send you a PM with instructions on how to log your device
Same problem here as well. Bluetooth audio through my Sennheiser headset is terrible on the ROG 3. No problem with my other phones though.
I have same issue. I use OnePlus bulltet wireless Z. When listening to audio or watching video sound disconnects for a split second and connects back. If I use wired headset audio is good. I don't have the issue in other phones when using the same headset.
A few days after I created the topic, the problem with the headphones was solved by itself, maybe I did something in the settings
a few days after I created the topic, the problem with the headphones was solved by itself, maybe I did something in the settings
Please let us know how you fixed the problem, still not able to ejoy connecting any bluetooth device, all devices are stuttering on Rog phone 3 abd it works well in cheaper phones :(
Yes, wireless and wired both headphones sometime makes loud noise while watching videos and listening music, it's really irritating
I don't know, I clicked the sound settings, also the developer settings, and one moment the sound stopped rattling and stuttering
Try to disconnect the wireless or hotspot and check again, this issues stop appearing when you are connected to wifi or when you open hotspot, but if you disconnect both and connected bluetooth alone sound ruttling will apear again specially when doing phone calls.
