Bluetooth headsets not supported by ICE Audio Wizard
- System: ASUS Vivobook 15 (windows 10 64 bit)
- Battery or AC:
- Model: X509FA
- Frequency of occurrence:
- Reset OS:
- Screenshot or video: Bottom right corner of the screenshot
Detailed description:The Audio Wizard application is not supporting my bluetooth headsets. Because of this I am unable to tweak the sound and enjoy it at its maximum best. Kindly suggest possible solution or any other alternative application. Thank you.
Comments
Hello dk_gautam,
So the Audio Wizard is working fine with built in speaker and audio jack?
Which brand and model is your bluetooth headset?
Yes AudioWizard is working fine with built in speaker and audio jack.
OnePlus Bullets Wireless Z - Bluetooth headsets.
Hello dk_gautam,
Thank you for your feedback.
I have consulted our technical support for more information about this.
Hello dk_gautam,
I'm sorry that Audio Wizard is not supported by any bluetooth headsets.
Oh OK.
