BATTERY PROBLEM
- System: windows 10
- Battery or AC: battery
- Model: X571GT
- Frequency of occurrence: regular
- Reset OS:
- Screenshot or video:
Why is my battery in my Asus X571GT draining quickly as it has been 2 months since I have purchased it please tell me a fix for it
Comments
Hello SHISHIR,
May you specify the issue?
Like how long were you using and how much % the battery drop?
What were you using?
Please kindly share a screenshot of your task manager.
it runs on intel gpu but while playing game it runs on nvidia gtx1650 the battery drains every 2hours
Hello SHISHIR,
So...what game is it ? and how many % it drop in 2 hours?
What was your setting? the screen brightness and how is the internet.
It's normal when you are gaming, the device is using the independent GPU and
of course game consume more power than other program.
the game is hyperscape, the battery drops to 15%,the settings are set to optimal in geforce experience
Normally., Dedicated nvidia gtx1650 gpu uses much power from available from battery , because this g[u have many cuda cores with advanced faetures.
