Android 10 beta for asus zenfone max pro m1
  1. Model Name:
  2. Firmware Version:
  3. Rooted or not:
  4. Frequency of Occurrence:
Guys, this is my opinion on android beta 2 update for asus zenfone max pro m1
Bugs:
1)sound : through headphones bass is lacking but can be increased with bass booster. You can get better sound quality with headphones
Through speaker is worst, it crackles always even with minimum sound
2)pubg hd graphics:it can be improved with gfx tools
3) settings : suggestions can't be removed
THIS ARE THE BUGS
Improvement:
1) battery backup is better than android pie
Believe me, actually I didn't take a screenshot but,
I got 10hrs sot with 3hrs of cod gameplay
2hrs chrome and 2hrs youtube
2) android 10 gestures :
When is display size is small (in settings)
There is a huge gap between gesture and screen
But when ur display size is medium it's superb
3) performance improvement :
I got the best score.
4)You get better black theme now and can be customised
5)U get game drivers in developer options
6)U get better animations while opening apps
CONCLUSION:
IF YOU CAN'T WAIT FOR ANDROID 10 STABLE UPDATE GO WITH ANDROID 10 BETA 2
U HAVE TO SACRIFICE SPEAKERS (HEADPHONES ARE GOOD)
I THINK THIS IS THE MAJOR BUG
AND REST ALL CAN BE SOLVED .
This is my opinion on android 10 beta 2
Comments
