(Max Pro M1) Battery Reminder Indicator notification
Model: Asus Zenfone Max Pro M1
Bulld no:- 084
Frequency of occurrence:- Daily
App name:- Settings.apk
When the battery indicator nearly about 6%... and after sometimes of usage... it jumps to direct 4% and it gives also warning notification... but it has to given on 5% of remaining charge, and it happens every time... This 084 is such a problematic Update of Asus Zenfone Max Pro M1... Please Asus Fix this Problem ASAP
The Warning Sign shows on 4% of Battery Charge, but this waring given should be on 5% of remaining charge...
Please give me some solutions to fix this... @Victor0_ASUS please give me some solutions
Thank You
Comments
@Victor0_ASUS please see this post
Hi @thegeralt1000,
I won't say this is a issue or it is normal.
Now coming to the topic, Missing 1% and even at 5-6 is very common and that to on a heavy usage like PUBG.
Help me with this:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
The Screen on time is the actual way to see how good or bad the battery is performing.
Okk, now i get it @ARP_ASUS
That's normal, my friend told me
And i want to tell you something regarding sound output issues, in 084 build in asus Zenfone Max Pro M1, shall i post a discussion or can i tell you the problem in same discussion
@ARP_ASUS
