HELP: I'm locked out of my device bc PIN is not recognized... Risk of data loss after 4 more attempt
DimxwzDimxwz Level 1
edited September 2020 in ZenFone 5 Series
  1. Model Name: Zenfone 5Z
  2. Firmware Version:
  3. Rooted or not:
  4. Frequency of Occurrence:
Hi everyone,
It seems that either I am not putting the correct PIN or my device doesn't recognize my correct PIN ( I tried many different ones, and I 'm sure that it should have unlocked by now), so I'm trying to find a way to unlock my phone without losing data through a hard reset..
An idea is to use the Google Device manager and set a new lock PIN, but my device is locked and not connected to WI-FI..
Is there another way to bypass the device PIN lock?? It's really a shame and frustrating experience that this might happen..
Any help is really appreciated!
Dimi
Comments
  • DimxwzDimxwz Level 1
    edited August 2020
    My device turns on and then it directly asks me "To start Android, enter your PIN", but it seems to have forgotten it..
    [EDIT]: also it says that after 4 more attempts, my data will be erased... Is there something that can be done?
  • Hi Dimxwz
    Thank you for your asking. Had you performed any specific steps below this issue happened? Does the issue appear after any system/apps' download or update? Have you ever faced this issue before?
  • Hi Christine
    Thank you for checking in..
    Actually not really... I was using my mobile and then my battery finished... then I charged it with my sister's cable which is from her Huawei Honor phone... (could this be an issue?)
    Is there anything I can do or you can do at ASUS to help me? I have access to my gmail account associated with the Android in my phone, so it's really bizarre I cannot reset my password...
    Thanks for helping
    Dimi
  • Hi Dimi
    Kindly try some stay-at-home troubleshooting tips below:
    A. Manage your Google Account PIN on Android
    https://support.google.com/a/answer/6136929?hl=en
    B. Please try the following steps to access recovery mode for the Factory Reset:
    0. Try to back up your data with USB cable
    1. Power off the phone, then keep pressing "volume down key"
    2. Press "power key" and stop press " power key" once you feel the vibration. Still keep pressing "volume down key".
    3. Stop press "volume down key" once you enter [Android Recovery] Screen
    4. Choose "Wipe data/factory reset">"Yes"
    5. "Reboot system now"
    #Hardware Reset Guide
    https://www.asus.com/support/FAQ/1006346/
    Please note that once the steps are completed, all data, apps, settings and personal information will be deleted.
