Call volume too low
Abdullah AlAbdullah Al Level 1
edited September 2020 in ZenFone Max Pro Series
Please tell us some basic information before asking for help: Calling sound volume too low.... I even don't hear what someone is telling....
  1. Model Name:Asus max pro m2
  2. Firmware Version:Android 9
  3. Rooted or not:not
  4. Frequency of Occurrence:From November 19 till now
Comments
  • we r facing this problem from 4 months
    still ASUS doesn't have any solution 😤😤😤😤😤
  • Abdullah AlAbdullah Al Level 1
    edited August 2020
    Please Asus solve this problem.... Otherwise i have to changed into a nother brand.. I really don't wanna do that..... It's a very big problem.... Please solve it ASAP
  • Hi friends
    Thank you for your asking. Because my device doesn't encounter the same problem with the same firmware, kindly try some stay-at-home troubleshooting tips below:
    1. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
    2. Also, please try "the Factory Reset"
    Settings>System>Advanced>Reset options>Erase all data(factory reset)
    Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
    If the situation remains the same after performing the Factory Reset, please bring your device to the repair center for device checking. You can also do some primary checking at home:
    1. Test the calling function with speaker/loud speaker/cable earphone/bluetooth earphone
    2. Check on SMMI test
    Calculator> type ".12345+=">SMMI TEST>Single Test>Speaker Test/Receiver Test/Headset Test
