(Max Pro M1) Facing Charging Issue After Update of 084 Build Update.
- Model Name: Asus Zenfone Max Pro M1
- Firmware Version: 084
- Rooted or not: No
- Frequency of Occurrence: Everytime
- APP Name & APP Version (If your issue relates to the app): Battery Related Problem
As we know Asus Released it's latest pie based security update (084)... Most of the users are facing lot of problems in this update... Specially i facing a major problem of
1. Charging Issue
2. Battery Backup Issue
3. Software Issue
1. Charging Issue:- in this problem the "Charging Rapidly" was vanished or disabled... But the power of charging in mA was upto 1200mA... But in 082, there is no problem was there... And the real charging time is 3 hrs to 3.30 hrs
(1to 100%) but in switch off mode (0 to 100%) takes 3.30hrs to 4hrs.
2. Battery Backup Issue:- the battery was not look like 5000mAh... It finishes like 3000mAh... Poor battery backup
3. Software Issue:- the main reason is software... Due to software the new new bugs was arrived... No fixes... No tests... Simply puse the updates... Even i clear cache, done factory reset... Still results are same so we can say that it's the problem of Software... Even i gone to asus customer service... They also said... Problem is not of hardware... Its the problem of software build 084.
Moderators, Admin... Please see this post and tell to developers that this is major problem not system fault or hardware Problem
Charging Rapidly is missing and showing 2hrs even i changed my charger and also brought a new charger
Charging in good condition and battery temp. Is normal... Still charging time 2hrs but actually it takes 3 hrs.
It shows 2hrs 8 min. But actually charges 2 hrs 50 min.
From 90 to 95% the charging speed decrease upto 600mA even also battery and system was good in condition...
Build number
Comments
Is this your first smartphone or something? Chargers push less voltage to battery when its close to being full, so it's not unusual to see less than full voltage over %90. It was always like this, i assume you thought you discovered America again.
No bro... I know but in my device on 95% of charge it starts charging Rapidly... That indication not showing
@Christine_ASUS now you can't see my thread... Only you saw my that inappropriate thread on that my Zenfone 5 thread... I am seeking for help and you ignore my thread...
Reply me... So i can tell the problem
Hi, we suggest you to please visit the nearest ASUS service center for better assistance. Locate here : https://www.asus.com/in/support/Service-Center/India
@Victor0_ASUS i want to ask something regarding my banned account how can i unlock my banned account
Sir now it's working fine because of USB To Micro USB cable of Original ASUS Cable was not durable... And it started Malfunctioning within a year... I would suggest that please ask them those manufacturers who made Adapters and Cables... Please tell them that these things are started Malfunctioning within a year... And not working properly....
On that Asus Cable It goes nealy 600mA and hardly 700mA... But i changed the cable... It works fine...
Here's the proof
This is the cable that i used now...
This is the reading now i get it... And also charging rapidly was also came....
Thank God it's showing 2hrs till full charging. Look at mine max pro m2......
You can downgrade your phone in Oreo 8.1 zero bug best performance
may god bless u bro
1 day 6 hr charging time is really OP
try different 10 w fast charger or different data cable or clean your charging pin from any brush
