Battery draining issue
nitin.media121nitin.media121 Level 1
edited September 2020 in ZenFone Max Pro Series
Battery draining issue and charging is also very slow
Comments
  • Hi, kindly help us with the following information to find a solution to your query.
    1.  Name of the Asus device you are using.
    2.  Firmware version your device is on.
    Also, in order to help you kindly help us with the following details:
    1. Kindly let us know the Charging time taken from 0 - 100%.
    2. What's the charging time difference between the current & previous update.
    3. Try another charger & let us know if there is any difference.
    4. Use the ASUS charger on a different phone & let us know the difference.
  • this doesn't help. i m using max pro m1 with firmware 084 and battery drains too much and charging time is too long and battery drains a lot even on battery saver mode+airplane mode. ASUS kindly fix it soon before i break my phone and change to samsung from asus. I ♥ Asus , but things like this makes me hate it.
