Rog phone 2 huge battery drain after 2007.27 update . Help!
After the recent 2007.27 update my device drains a lot of battery while gaming. And I can also find noticable drain without gaming as well. Please help me which ks causing the issue . I'm not even getting 5hrs of screen on time . Help me . And there is warranty for my device , if I want to change the battery pack will it be covered under warranty ? Will this issue be solved after the battery replacement ?
Comments
Same issue here
Can you please share the battery time screen shots ? .
Same here
Yeah . Yours look decent . Mine is awful ☹️
Try accubattery ,it tells us the present battery capacity
Mine has reduced to 4900 mah in 6 months
I am also facing the same issue. For me it is shown that the android system uses most of the battery. Please help.
All this started to happen after the latest update.
Hi @kiranmsd32
This can be related to software/hardware.
If your device is in warranty the hardware is covered if there is any technical falut.
Have you tried factory resetting the phone?
Sometimes factory resetting helps your device to perform better and fresh.
Yes I can confirm the same issue. MASSIVE drain from the Android system group 83% of the battery. Since 2007 and now 2009.
Battery health is 5300+ ma after a year, but the drain will go between 600+ ma to 1000+ ma per hour at (idle screen on). On the home screen. All apps closed. None running in background. 60hz min brightness.
Factory Restoring does not help with the issues.
I can barely get 5-6 hours out of the device now
I was apart of the official A10 beta program. More than happy to logcat if we can get it looked at. Please PM me with what you would like logged my sirs.
Thank you for your time and help!
