AI charging option is not available and battery is charging slowly
Model Name:Asus Zenfone 5z
Firmware Version: Android 10
Rooted or not:Not rooted
Frequency of Occurrence:2 days
Debasish_Sahoo
Zen Master I
AI charging option has been removed in Zenui6 (Android 10). And regarding Charging slowly make sure that your battery care option is off and see incase you have activated schedule Charging. If this issue still not solved then try to charge with another cable because its due to bad cable/ Adapter that makes your device charging slowly.
Thanks!
