Cam region Pick ups heat | Build 165
Camera module and surrounding area heats up within few minutes of using camera app
* If used for longer duration, that's fine but it heats up real quick
Please check it
Please check it
Comments
Same problem here, the camera unit gets so heated up that I try to cool it manually. I'm on the latest build and updated.
This is normal behaviour and nothing to be concerned about. Because the camera sits in a metal housing it's more noticeable when it gets hot.
Question is soon after the launch , within 2 mins starts heating up
It was not like this in Pie, unless we start using it extensively , like shooting video for more than 15mins or playing with Pro mode
You're welcome to visit a service center and ask them to investigate. Should be easy for them to replicate if it only takes 2 minuts
Waiting for the updates, expecting bug fixes or improvements, if facing issues visit the service centre .. interesting ..thanks for the advices
