Mic issue while playing Pubg (Zenfone Max Pro M1)
- Model Name: Zenfone Max Pro M1
- Firmware Version: .082
- Rooted or not: Not Rooted
- Frequency of Occurrence: Every time
- APP Name & APP Version (If your issue relates to the app): PUBG Mobile
In .082 update, while playing Pubg the microphone doesn't work , when I switch on the microphone in Pubg it does switch on but other team mates can't listen to me and tapping the volume buttons it shows the in call volume panel with media volume whereas the in call volume panel should not be seen.
COMMENT IF YOU PEOPLE TOO FACE THIS OR SOME FIX.
0
Comments
Hi there, kindly check the microphone of the device if it is working fine or if there is any issue with it, also check if you have enabled all required parameters in PUBG under Audio option and see if the issue is there.
