Max pro m2 free fire mic not working on android 10 beta 2
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
0
Comments
Hi there request you to follow the below steps:
1. Check your phone for latest software version.
2. Go to Free Fire App settings and see if all the required permissions are granted.
3. Clear cache & storage of the App after backing up & disable/re-enable the App.
4. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
5. If still you face the issue factory reset your phone after taking a full backup: https://www.asus.com/support/FAQ/1006346/
