Does Asus Vivobook X512FL supports charging battery and Display on Type C port ?
- System: Asus Vivobook
- Battery or AC:
- Model: X512FL
- Frequency of occurrence:
- Reset OS:
- Screenshot or video:
Detailed description:It would have been good if the charging the battery and Display on Type C port was enabled. Kindly suggest if it works.
Ashwin
Comments
Hello Ashwin,
The USB C port on this model does not support Display and Power in or out.
It's for data transmission only.
Thanks for the response, Blake.
That was pretty straight in terms of technology limitation on this model. Thanks again
