Battery Problem
Aaditya D.Aaditya D. Level 1
edited September 2020 in ROG Phone 2
My Battery Is draining faster then before. After playing PuBg only for 3 hr without X Mode it's come to 13% from 100 %
Any one having same problem.
plz send some solutions
I attached screenshot
Comments
  • my pc have battery issue
  • Unless you're playing outside (forcing the screen into super brightness) I would say there's something wrong. So if you're gaming inside, and only get 3h, then I recommend you to backup and factory reset your phone. If that doesn't help then check with your service center if you still have warranty on your battery.
